Midyear glue - NCRS Discussion Boards
Midyear glue
+ More Options
Posts
  • Jeremy H.
    • January 1, 1999
    • 260
    Midyear glue
    Got counted off at Bloomington, on a 67, for the wrong color of weatherstrip glue. I know it is yellow and from what I have seen on survivors it is yellowish brown, but I figured that was age. Anyone found any new yellowish-brown glue to use? 14 Top Flights and 11 Bloomington Golds and this is the first time I have ever been counted off for this.
    Jeremy Hedges
    #31711
  • Harry S.
    • July 31, 2002
    • 5328
    Re: Midyear glue
    Jeremy, I believe the glue when originally installed was clear. The yellow/brown came with age.
    Let's see what others say.
    • Dick W.
      • 10483
      Re: Midyear glue
      As I have posted before, use contact cement. Available at Lowe's, HD, Ace, etc
      Dick Whittington
      • Jeremy H.
        • January 1, 1999
        • 260
        Re: Midyear glue
        You mean like pvc glue?
          • 6948
          Re: Midyear glue
          Jeremy Hedges
          #31711
          Jeremy, I used a stuff that the company Wurth makes, weatherstrip adhesive, great stuff and brushs on and looks like that factory, that has a light brownish color, the yellow stuff that 3M makes is good stuff but sticks out like a sore thumb.
          • Rick A.
            • July 31, 2002
            • 2147
            Re: Midyear glue
            have to agree with Harry - origie was CLEAR and yellowed with age
            Rick Aleshire
            2016 Ebony C7R Z06 "ROSA"
            • Hank D.
              • January 1, 1999
              • 137
              Re: Midyear glue
              Hi Rick -
              Yes, I believe John Hinckley also indicated during his seminar last week at Novi that the glue was clear when initially applied. So, given that, what is the best way to prepare a car for Flight Judging?
              Hank
              • Dick W.
                • 10483
                Re: Midyear glue
                No, the glue used for vinyl flooring, laminate counter tops, etc. Has a very light tan tint to it.
                Dick Whittington
                • Rick A.
                  • July 31, 2002
                  • 2147
                  Re: Midyear glue
                  Hank,
                  would do / use contact cement as Papa Smurf recommends
                  Rick Aleshire
                  • Ronald L.
                    • October 18, 2009
                    • 3248
                    Re: Midyear glue
                    The stuff Dick is referring to is amber and will be a perfect match, you ahve to be fast as the solvent bites into the paint. It essentially is the same stuff they used back then.
                    • Steve B.
                      • March 1, 2002
                      • 1190
                      Re: Midyear glue
                      Originally posted by Hank DeMartino (31594)
                      Hi Rick -
                      Hank
                      If John is correct which I will assume that he is, why do judges demand seeing yellowed glue on restored cars? I understand wanting to see yellowed glue on a bowtie car but for a freshly restored car, it doesn't make sense but then again, I am not the sharpest knife in the drawer
                      • Domenic T.
                        • January 29, 2010
                        • 2452
                        Re: Midyear glue
                        Steve,
                        You are not the dull knife either.
                        If the factory worker was instructed to be SLOPY with his or her work that's one thing.
                        But history teaches us not to repeat mistakes, SOOOOOO if you see yellow on my door it was because I couldn't do it right either?
                        Imagine what the vette would look like with every reproduced mistake.
                        I have respect for the way others are doing the hobby but I am doing every thing myself on my vette and it will be a reflection of MY work, not BUBBA's.
                        DOM
                        • Dick W.
                          • 10483
                          Re: Midyear glue
                          They don't necessarily want to see yellowed glue, they just do not want to see the bright yellow "gorilla snot" glue.
                          Dick Whittington
                          • Timothy B.
                            • April 30, 1983
                            • 5193
                            Re: Midyear glue
                            Dick,
                            I assume you are using something like that weldwood contact cement available at the HD..
                            • Dick W.
                              • 10483
                              Re: Midyear glue
                              Bingo! I could not think of the name Tim. Too sorry and lazy to walk out in the shop and look at the can. Guarontee the weatherstrip not to come loose if you follow the instructions on the can. Might pull the door off the car, but the weatherstrip will not turn loose!
                              Dick Whittington
