Re: Car fire followup question, electric fuel pump cutoff
Steve,
Here's an excerpt from what's in the original post:
"Since the pump , a Walbro GL392 is capable of 255 LPH at 130 psi, I definately need a way to stop the pump besides using the ignition key."
Bruce wants a separate shutoff switch, not the ignition switch. If you did want to use the ignition switch and you wanted to switch the ground, you could use a relay to do that. I don't believe Bruce mentioned where he wanted to mount the switch, so I don't know that we're running any wiring through the firewall back to the dashboard.
"Also there is no less voltage or current on the ground wire than there is on the hot wire. There both the same potential all the time."
What???? The hot wire is at nominally 12 Volts DC, the ground wire is at, well, ground (0 Vdc). Now, as far as current goes, assuming that the only load on the two wires is the fuel pump, they will both carry the same amount of current.
Joe
					Steve,
Joe
