Support Bracket on 1960 Starter - NCRS Discussion Boards
  • Joe M.
    • April 30, 1990
    • 1342
    My car has a PG transmission and there is no bracket from the starter to the PG? The only bracket I observed last night was the bracket holding the blowdown tube to the starter bolt. Would the brace in question be CC part number 301170, 56-62 starter motor brace?
    Where does this bracket attach to the starter? PG?
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: Support Bracket on 1960 Starter
    Joe,
    If it's the one I 'm thinking about it attaches to the block from one of the 2 starter bolts that holds the starter together.
    The bolt is threaded after the head 1/4 X20 and the bracket bolts from there to the block.
    DOM
    • Joe M.
      • April 30, 1990
      • 1342
      The 1958-1960 Tech Info Manual/Judging Guide states "Forward end of starter housing is supported to engine block with a metal brace on cars equipped with PG trany." Does it bolt to the nose of the starter?
      • Domenic T.
        • January 29, 2010
        • 2452
        The starter head is rear and the starter back is forward.
        The bracket I have always seen was there for PG or stick.
        It looks like a dog leg and is bent from angle iron stock.
        DOM
        Originally posted by Domenic Tallarita (51287)
        Joe,
        DOM
        • Stephen L.
          • May 31, 1984
          • 3162
          "Forward end" would be the end away from the transmission and flywheel.
          As stated earlier the bracket would attach to the front end (flat end of the starter) and the engine block. It supports the end that "hangs out in space".
          • Joe M.
            • April 30, 1990
            • 1342
            Now I know what the long threaded bolt that protrudes from the flat end of the starter is for. My starter has been hanging out in space for a long time. Time to remedy that! I am not sure why the bracket is described for PG cars only; seems like it would be useful for all cars to support the starter. Thanks to all for the info.
            • Timothy B.
              • April 30, 1983
              • 5201
              I don't know much about C1's but I suspect the brace is used when the starter mounts to the block. Manual transmission C1 starters bolt to the bellhousing using three bolts so no chance the block could be damaged by the starter hanging out.
                • 43273
                Joe------
                For 1962 Corvettes, only Powerglide-equipped cars used a block mounted starter. 1962's with manual transmissions used a bellhousing-mounted starter. It's only applications with a block-mounted starter that used the starter brace, so that's why only 1962 Corvettes with Powerglide used the brace. The brace was originally GM #3816511, later GM #3851294, and, finally, GM #354353 which remains available to this day. There are slight configuration differences between the braces but all are functionally interchangeable.
                • Joe M.
                  • April 30, 1990
                  • 1342
                  Joe, now I am confused. Are you saying that my 1960 w/ PG never had the front brace as described in the 1958 - 1960 Tech Manual and Judging Guide?
                    • 43273
                    Joe------
                    Somehow, I thought we were talking about a 1962 with Powerglide. Anyway, I believe 1958-62 Corvettes except those 1962's with Powerglide did use a starter brace but it was configured completely different than the brace used with 1962 Corvettes with Powerglide as well as later Corvettes.
                    • Joe M.
                      • April 30, 1990
                      • 1342
                      Since I have never seen an original, I hope it looks like the brace that CC sells as "1957-1962 Starter Brace."
                        • 43273
                        Joe------
                        I don't have a copy of the 1960 AIM. Does the AIM show a brace being used and, if so, what is the part number?
                        • Gary C.
                          Administrator
                          • October 1, 1982
                          • 17930
                          Joe,
                          Brace is in Group 2.077 p/n 3742856 - listed for passenger car
                          Gary
                          NCRS Texas Chapter
                          https://www.ncrstexas.org/
                          • Joe M.
                            • April 30, 1990
                            • 1342
                            Thank you Gary. I searched in the 1960 AIM and the page showing the starter does not show a brace; RPO pages dedicated to P/G do not show the brace. There is a great photo of the brace on a car in the 1958-1960 Restoration Handbook DVD. An excellent restoration guide. I am going to purchase the brace from one of the big vendors.
                              • 43273
                              Originally posted by Gary Chesnut (5895)
                              Joe,
                              Gary
                              Gary------
                              Yes, I saw the brace you mention. However, as you also mention, it is specified for passenger car applications. Coupled with the fact that Joe reports that no brace is shown in the Corvette AIM, I question whether the brace was ever originally installed on Corvettes. Perhaps they were once installed as a result of some sort of service bulletin which may account for the fact they are found on Corvettes.
                              It's hard to imagine that St. Louis would have been installing a part that was not shown in the AIM.
