1972 small block temps - NCRS Discussion Boards
  • Carl E.
    • February 7, 2011
    • 14
    I have a 72 350/200hp. The temp. gauge runs a steady 230/235 and when I shoot the block and other areas around the engine compartment with my Lazer- I get 184/196. I know the manual says, under operating conditions, gauge should read 235. Is this normal or should I get a new gauge? Thanks, Carl
    • 15706
    Re: 1972 small block temps
    The normal operating temperature range for your engine is 195-230F, however it should only reach the high end in hot weather, low speed traffic.
    Many replacement temperature sensors give high readings on the gage. The Wells TU-5 is supposedly most accurate.
    • Carl E.
      • February 7, 2011
      • 14
      Thank You for your input. Carl
      • Don L.
        • August 31, 2005
        • 1006
        FWIW, my '72 (350/200) no AC, 4 speed typically operates in the 180* - 190* range. On very hot days when in traffic, it climbs to just in excess of 200*. Once I start moving it comes right down to the typical temp range.
        I've checked/confirmed the gauge to be reading + approx 5* with a pyrometer.
        I hope this helps you.
        Don Lowe
        NCRS #44382
        Carolinas Chapter
        • Carl E.
          • February 7, 2011
          • 14
          Thanks for the info. Carl
