327 cross fire between plugs 2 and 4 - NCRS Discussion Boards
  • Anthony P.
    • June 27, 2010
    • 485
    I have had one cylinder (#4) that seems to not burn as clean as all the others. It had allot of carbon buildup after 2k miles to the point where it was missing, and all other plugs were near perfect. I recently did a complete tune-up and noticed that that plug again is still not clean as the other even after a few hundred miles..
    I am going to do a compression test, but what I noticed using a plug/wire tester was a crossfire FROM wire #2 TO #4 at the #4 plug. I have the wires all routed correctly (I think) in the loom, and all shielding is in place.
    I thought that a while back I read something about a possible crossfire issue and Chevy recommended something back in the 60's but can't find it.
    I am using the correct type reproduction wires.
    Any thoughts?
    Thanks again,
    Tony
  • Bob R.
    • June 30, 2002
    • 1595
    Re: 327 cross fire between plugs 2 and 4
    The reproduction wires can cause problems. If you have another set of wires try them and check the results.
      • 15706
      Check wire resistance: s/b no more than 5K ohms per foot.
