1965 Coupe Vintage Air - NCRS Discussion Boards
  • Dean S.
    • December 15, 2010
    • 68
    When you open the hood of your car at a NCRS event to be judged, are the judges turned off immediately if you have Vintage Air, because your car did not have air to begin with? How does it look installed ? Similar to the factory a/c? Any extra unwanted chrome accents in the engine compartment? Or is it a nice factory look. Aiming for Top Flight or 2nd Flight to start and then go from there.
  • Dean S.
    • December 15, 2010
    • 68
    Re: Best Exhaust system to replace my "side pipes" for Judging
    What is the best set of stock exhaust to "please" the judges as I am removing my side pipes.
    • Russ S.
      • April 30, 1982
      • 2163
      This is up for all kinds of opinions but I would say Corvette Central but specify CS after the part number for carbon steel. Just be aware that carbon steel rust in time.
      • Michael J.
        • January 27, 2009
        • 7145
        Re: 1965 Coupe Vintage Air
        Yes, I have seen judges snear at Vintage Air, the compressor, tubing, etc. are totally different from a stock A/C, as is everything else about it, including air box under the passenger side dash. So as I mentioned in your other thread, the point deduct will depend on how much of a purist the judges are, there is some subjectivity and looking closely required, which varies. And yes, carbon steel is the only material for exhaust pipes to pass the magnet test.
