Turn signal housing harness - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 500
    Is there a special way to install the housing and thread the wires into the shaft? Thanks folks!
  • Mike M.
    • May 31, 1974
    • 8408
    Re: Turn signal housing harness
    i instal(fasten)l the directional signal switch/harness in the bell first, then thread the harness between the shaft and mast jacket. if the dir signal switch harness's wires aren't molded together like the originals were,i'll super glue the six wires together to facilitate passing the six wires inside the mast jacket to their exit. good luck,mike
    • Guy M.
      • November 1, 1993
      • 500
      Thanks Mike, I sure appreciate that!!
      • Dan D.
        • November 5, 2008
        • 1323
        That's what I did on my 57. Worked good. Went in easy. -Dan-
