6" wheels w/wheelcovers - NCRS Discussion Boards
  • Steve V.
    • June 27, 2011
    • 95
    Is there a 6" wheel with the correct offset available that will hold the wheelcovers on on a 60 model?
    Opportunity is missed by most people
    because it is dressed in overalls and looks like work.
    Thomas Edison
  • Mike M.
    • May 31, 1974
    • 8402
    Re: 6" wheels w/wheelcovers
    [just get 4 6" wheels that will fit inside the wheel wells. then use a mig welder to fabricate the 4 teats that are similar to the 4 teats on your stock 15 x 5" wheels and the hubcaps will stay put. mike
    • Robert S.
      • May 31, 1988
      • 81
      If you are going to go to all of that trouble, (worth it in my opinion) you may as well use seven inch wide wheels with a 3 3/4 inch backspace. Makes a 215 R 70 tire look really good. Especially with Diamondback wide whites.
      Bob
