'63 Install Washer on wiper motor - NCRS Discussion Boards
  • Jack Y.
    • June 30, 2005
    • 76
    I have checked the archives but still having an issue with mounting the washer unit on the wiper motor which is still installed. I can't seem to be sure the metal drive pawl on the wiper is engaged with the plastic star wheel on the washer unit. I even filled the plastic cavity with grease, installed the washer and removed it to see if it had displaced the grease. It did not but the unit fit flush for attachment. There are only 4 positions on the star wheel and I tried all four. Do I need to run the wiper motor to change the position of the metal pawl? I hesitate to attach it and run the wipe as I am afraid if it is not aligned it may destroy the plastic star wheel. I have no idea if the washer was in the correct position when I removed the washer and I did not run the wipers before or after I removed the washer.
    Thanks in advance!
