Ignition Shielding Restoration/ Replating - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    Hi all,
    I need to have a 67 ignition shielding box redone. Can anyone suggest an outfit to re-chrome it correctly.
    Dave
  • Mark D.
    1984-86 Team Leader
    • June 30, 1988
    • 2152
    Re: Ignition Shielding Restoration/ Replating
    Richard Fortier
    Kramden
    • Stuart F.
      • August 31, 1996
      • 4676
      Isn't it Stainless SteeL?
      Stu Fox
      • Ronald L.
        • October 18, 2009
        • 3248
        BB no. Most of the SB, no too.
        The issue will be where ever you go, the plater will want to polish out all the die marks, etc that are in the originals.
        • Patrick T.
          • September 30, 1999
          • 1286
          Isn't it Stainless Steel? Stu Fox
          It's SS with Flash Chrome. PT
          • Gary B.
            • February 1, 1997
            • 7024
            To reiterate, some ign shield items are SS and some are not. The non-SS should be flash chromed. I'll give another vote for Richard Fortier. He knows how it was done originally and he knows who can replicate the original look. I wish I had talked to Richard before I had my non-SS ign shield items incorrectly triple plated some years ago.
            Gary
            • Scott S.
              • September 11, 2009
              • 1961
              Originally posted by David Schutzbank (50698)
              Hi all,
              Dave
              Dave,
              If you are only referring to the small block ignition top shield (1967 AIM, U69-A8, Item 5, 3882700), it is stainless steel, and it does not (and should not) have any chrome plating.
              If I remember correctly, the LH front and rear horizontal ignition shields are also stainless steel. For the others, the blueprint authorized either stainless or cold-rolled steel with flash-chrome, but for reasons unknown, the suppliers used cold-rolled steel with flash-chrome for the other ignition shields. John Amgwert has an excellent article on this subject in one of the Restorer Magazine back issues.
              • David S.
                • August 9, 2009
                • 595
                Guys,
                To clarify it is a 67 BB (L71) ignition shielding....
                Dave
                • Scott S.
                  • 1961
                  Guys,
                  Dave
                  Well, that changes everything
                  The 1965 big block ignition "box" is described as being chrome plated in Adams, p. 304. The part number changed during 1965 production, then again in 1966 and once again for 1967. I suspect only minor configuration changes. As others have mentioned, I would also try Richard Fortier to get the correct flash-chrome finish.
                  • Ronald L.
                    • October 18, 2009
                    • 3248
                    David, the BB's were plain steel with flash chrome and rust easy if exposed to moisture, see my email to you regarding suggestions to keep the finish looking original.
                    • Chuck G.
                      • May 31, 1982
                      • 2034
                      I had my 69 BB valve covers flash chromed by Todd Librandi at Librandi's Plating in Harrisburg (Middletown) PA.
                      You have to call Todd personally, as he normally won't do it.
                      Many guys don't really know the poor quality of flash chrome, and he doesn't want re-do's.
                      Chuck
                      • D S.
                        • March 1, 2005
                        • 1551
                        I've had all four sets of 1970 Corvette 454 valve covers and three ignition shielding boxes done by a plater in Fort Worth, Texas. Flash chromed and they did a great job of duplicating the poor quality of GM chroming back in the day. Love it. However, when the plater polishes the metal and then triple plates the item the original detail and characteristics are forever lost. I've seen many original chrome valve covers with drippers that were triple plated and they look wavy and way too glitzy. Ask the plater first if they know how to flash chrome. Many don't. Make sure you are both on the same page even if you have to show the plater an example of an item previously flash chromed.
                        Scott Sims
                        Texas Chapter
                        • Jerry B.
                          • August 31, 1994
                          • 416
                          What is flash chroming? thanks
                          • Chuck G.
                            • May 31, 1982
                            • 2034
                            MY definition is chrome plating put right on top of the metal, without prior copper and nickel coats.
                            The copper, nickel, chrome process is referred to as "triple chrome plating".
                            Chuck
                            • Wayne M.
                              • March 1, 1980
                              • 6414
                              Here's the 2nd design (large keyhole) 1965 BB distrib surround shield, unrestored AFAIK [missing front ground clip]. I notice that Noland's Vol 2 also calls the '66 design as chromed steel, so I assume same for '67. Also, the "patina" on a '67 is probably similar to this example.
