65 AC blower problem - NCRS Discussion Boards
  • Don H.
    • December 1, 1981
    • 1496
    I just finished putting the air conditioning back in the '65 for the Road Tour to Novi. I changed the evaporator so I was near the motor but it was not out. I charged it tonight and all seems well except the blower motor only blows when set to high. I also had the radio out recently so I could have bumped the switch wires. Any suggestions where to start? Thanks, Don H.
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 65 AC blower problem
    Donald do not know if this applys to a 65, however my 1970 with factory air has a separate inline fuse for the high speed blower speed. This fuse is actually under the hood and in the engine compartment. The other blower speeds are fused from the main fuse block on the drivers side. You could have a blown fuse here.
    • Don H.
      • December 1, 1981
      • 1496
      Thanks Jim, I guess I should have checked it before posting (time is short, I leave Friday). The blower motor relay & fuse (which I had out) was the problem. Thanks, Don H.
