1967 engine numbers -date code for intake-heads - NCRS Discussion Boards
  • Mark U.
    • June 7, 2009
    • 70
    my 427 vert was born on may 22,1967
    i take it that the heads and intake dates should fall between
    c-22-7
    d----7
    e-22-7
    thakes for all your help
    Mark
  • Patrick T.
    • September 30, 1999
    • 1286
    Re: 1967 engine numbers -date code for intake-heads
    Maybe this will help. My SB engine build date in Flint was July 3, 1967.
    The casting dates on my heads below are 2 days apart, June 6th, and June 8th, 1967. It appears the heads were cast about a month before the engine assembly build date.
    • Scott S.
      • September 11, 2009
      • 1961
      Mark,
      The build date on my '67 is January 11, 1967 (both on the Trim Tag and confirmed by the NCRS shipping data report). The original L79 small block engine pad with correct matching VIN # is stamped VI230HT (for December 30th, 1966). The engine block casting date is L276 (December 27th, 1966).
      The left head is dated L26 (December 2, 1966) and the right head is dated L126 (December 12, 1966).
      The aluminum intake manifold is dated 11 . 28 . 66 (date cast into the underside of the manifold)
      • Michael W.
        • March 31, 1997
        • 4290
        c-22-7
        d----7
        e-22-7
        Mark
        The day the car was completed is not of relevance- the day the engine itself was assembled is the key. That's the date shown on the engine stamp pad.
        The date of the components you mention must precede the engine assembly date, 1-2 weeks is very common.
        Last edited by Michael W.; July 12, 2011, 07:26 PM. Reason: clarification ,judging rules not relevant either!
        • Mark U.
          • June 7, 2009
          • 70
          i thought there was a 90 day window on the engine and its parts,am i wrong?
          • Joe R.
            • May 31, 2006
            • 1822
            Mark,
            As far as NCRS judging goes, the window is six months. Some of my engine components were 4 months prior to the date on the engine pad if I remember correctly.
            Joe
            • Mark U.
              • June 7, 2009
              • 70
              thank you for the info,when putting this vette together just trying to get it right the first time.
              • Michael W.
                • March 31, 1997
                • 4290
                Mark,
                I had originally made mention of the six month window in my post then later deleted it as it possibly confused the issue more than helped.
                Be aware that the dates codes on heads and BBC intake manifolds are not judged.
