My question is about tuning a carburetor for best lean cruise A/F ratio 35-45-55-65 MPH, and the main jets are reduced to where the engine surges then up one size at a time until it's steady with no surge. At this point is the ratio considered 14.7 or could it be leaner than that.
In reading, this is the correct procedure but not sure how to tell if it's leaner than stoichiometric. After determining this, a 25% increase in sqin. area for power enrichment would equal 50% of the main jet diameter which should yield 12.5 A/F ratio for best power. This would compute to the PVCR size, so if the main jet ended up at .065 (#65), the PVCR (power valve channel restriction) would be approx .033 (50% of the main jet size) compared to the .039 that is in my 3810 holley.
It's my understanding the holley carbs are rich at cruise and power enrichment..
Leaning main jet cruise this way so the engine is telling you how much fuel it wants could also be double checked with a O2 sensor if a bung is installed in the header pipe and read with a DVOM showing the voltage at cruise. I read 450MV (millivolt) is stoichiometric so we would not want to be leaner than that at cruise conditions.
All thoughts are appreciated..
