Anti Freeze - NCRS Discussion Boards
Anti Freeze
  • William G.
    • April 1, 1978
    • 154
    Anti Freeze
    Getting ready to put anti freeze in 1965 327/300hp amd start it .
    Iam going to put Zerex G-o5 in it and is this ok. This is a rebuilt motor
    and has not any anti freeze in it since rebuilt. Also using distilled water.
    BILL
  • Jim D.
    • 2883
    Re: Anti Freeze
    Zerex G-05 is definitely the one you want to use.
    • Philip C.
      • December 1, 1984
      • 1117
      Re: Anti Freeze
      BILL
      Hi Bill I would use only water for the run in to test for leaks, if everything OK then drain and refill. Phil 8063
      • Brian M.
        • February 1, 1997
        • 1838
        Re: Anti Freeze
        I'm with Phil, water is easier to clean up if a leak is found.
        • William G.
          • April 1, 1978
          • 154
          Re: Anti Freeze
          Thanks for the reply.Car has been setting for 29 years and stated restoration 2 years ago. Just completing the restro.I have never
          had the car started. So tomorrow is the day and sure hope she
          starts up. I like the idea of just using water and then drain after
          no leaks.
          Bill
          • John D.
            • December 1, 1979
            • 5507
            Re: Anti Freeze
            Hi Bill, Hope you didn't make the mistake I did on my 63 the 1st time it was restored back in 1979 or so. The radiator didn't leak a drop. But at that time I didn't know you were supposed to keep antifreeze, etc in the rad when it was off the car. so about 3 yrs later when the radiator was installed it leaked like Niagara Falls. John
            • William G.
              • April 1, 1978
              • 154
              Re: Anti Freeze
              Hi John
              I PUT IN A NEW RADIATOR SO SHOULD BE NO PROBLEM.
              OTHER ONE HAD A HOLE IN IT THE SIZE Of MY FINGER.
              BILL
