C1 screw/bolt - NCRS Discussion Boards
C1 screw/bolt
+ More Options
Posts
  • Robert I.
    • July 31, 2004
    • 164
    C1 screw/bolt
    My 62 has a screw or bolt with kind of a "butterfly" opening on it, on the strap for the coolant tank.
    Just noticed the same bolt is on the hood support.
    I suppose you could use a screwdriver, but does someone make a special tool for these?
    Thanks in advance.
    ____________________
    Bob Immler
  • Anthony P.
    • June 27, 2010
    • 485
    Re: C1 screw/bolt
    That is called a "clutch head" bolt and there is a special tool. You can find teh tools on Ebay and other places in sets.
    here is an example on ebay: http://cgi.ebay.com/ebaymotors/1955-...#ht_500wt_1182
    Yes you can use a screwdriver, however, it depends upon how tight they are.
    hope that helps,
    Tony
    • John F.
      • March 23, 2008
      • 2427
      Re: C1 screw/bolt
      I think you have the wrong fastener in the strap. Clutch-head screws are used on the hood brace where it attaches to the fender. The bolt to the hold-down strap on the expansion tank has a 7/16" head. You can buy a set of clutch-head screwdrivers at most tool places.
      • Robert I.
        • July 31, 2004
        • 164
        Re: C1 screw/bolt
        "I think you have the wrong fastener in the strap."
        Ah, so that's why it doesn't start<G>!
        In pictures like these, I'm so happy to see that other people have cars that aren't perfect.
        Bob Immler
