help on engine numbers - NCRS Discussion Boards
  • Mark U.
    • June 7, 2009
    • 70
    i have a 427 390 hp 1967 vert-here are the engine numbers
    block-3904351
    heads-3964290-3931063-1 head was replaced by the factory under warr work
    intake 3963569
    i beleive the intake is not correct and should i try to replace one of the heads or is it right to have a replacement head on this car? I am trying to keep it as original as i can.
    Thanks Mark
  • Tom H.
    • December 1, 1993
    • 3440
    Re: help on engine numbers
    Hi Mark ! I think your heads should be cast 3904390. Intake, 3866948 or possibly 3883948 depending on the production date.
    I'm sure someone will chime in with more detailed information.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • John C.
      • January 1, 2005
      • 616
      Mark
      Your block should be casting 3904351 like you have.
      There are 4 possible heads used on a 67 390hp car. They are-
      3872702 - very early cars
      3904390 - through Dec 66
      3909802 - Jan 67 to near end of production
      3917215 - very late cars
      There is a head casting 3964290 but it was used for the 1969 model year. Check your head number again as they are very easy to misread.
      Your replacement 3931063 head was also used for 1969 cars. They will be minor accessory mounting pad difference between the correct 67 heads and this one but I doubt anyone would notice.
      The correct intake manifold should be either casting 3866948 or 3883948.
      Bubba has been at work on your current intake manifold. 3963569 is for a 1970 and 71 LS6. This manifold is meant for square port heads and not the oval that you have. It is also a low rise manifold and not the high rise style used in 67. What do you currently have for a carburetor on this?
      John
      • Mark U.
        • June 7, 2009
        • 70
        guess i need some numbers for heads and intake numbers..
        Thanks Mark
