67 headlight switch question - NCRS Discussion Boards
  • Chuck M.
    • February 1, 2002
    • 335
    We were having some issues with the headlight switch. The rheostat seemed to be dirty since we could not get the gauges to dim properly. Also when turned to what would be the max on position the dome light and under dash lights will not come on. We were able to clean the rheostat but the dome light still will not come on. Is there a trick to making this work. Am I missing something? Is the switch dead?
    Thanks for the help
    Chuck
    • 6955
    Re: 67 headlight switch question
    Charles, sounds like your on the right track, the rheostat may have a open somewhere, or the copper contact part is not touching at some spot on the rheostat when turning. The dome lamp part is a solid copper contact at the end of the rheostat.
    • Chuck M.
      • February 1, 2002
      • 335
      Thanks Edward! I think we are going in the right direction. We have the dim function working properly but cant seem to figure out why the dome light function isnt working properly. The tab looks like it is making proper contact but we cant seem to make this work.
      • Timothy B.
        • April 30, 1983
        • 5201
        Charles,
        Are you sure the dome light is good, stranger things have happened..
        • Chuck M.
          • February 1, 2002
          • 335
          Here are a couple o picture of the switch we pulled out of our car and a new one. They look quite different and the new one will not fit due to the size being larger. Any thoughts?
          Thanks again for the help.
          Chuck
          • Chuck M.
            • February 1, 2002
            • 335
            Hi Tim,
            Yeah the dome light comes on as it should when the doors are opened. Thats the only way I know to tell if its good?
            Chuck
            • Joe R.
              • July 31, 1976
              • 4552
              Charles,
              That replacement switch is correct for 64-67 and it will fit. It's tight but will fit. Give it another shot!
              JR
              • William C.
                • July 15, 2009
                • 239
                Thanks for the help
                Chuck
                Chuck..I had the same problem and the contact was insolated. When you turn the switch to the dome light position look for the contacts and clean them with a contact file..Bill
                • Timothy B.
                  • April 30, 1983
                  • 5201
                  Someone correct me if I am wrong but in 1967 the H/L switch when pulled the first notch for parking lights front and rear lit and second notch for H/L the front parking lights are not lit.
                  The replacement switch has the front lit all the time when in use.
                  • William C.
                    • July 15, 2009
                    • 239
                    Timothy...Correct for the original, but I don't know about the replacement..Bill
