Lessons learned - NCRS Discussion Boards
Lessons learned
  • Steven A.
    • March 29, 2009
    • 14
    Lessons learned
    Things I learned today:
    1) Thinking I was smart and trying to use FelPro 1630 valve cover gaskets, (because they were recommended), with my original BB valve covers and and "RBW" bolts. Not so much; the bolts are too short for the thicker gaskets.
    2) The original/correct gaskets with the silver seal work just fine; "no runs, no drips, no errors".
    Finally, 3) sure is a lot easier if you just stick with original.
    • 43272
    Re: Lessons learned
    Steven-----
    Yes, the original style gaskets will work just fine to begin with. However, over the long haul they won't be as durable and as leak-resistant as the Fel-Pro corkprene with steel insert (i.e. 1630). Believe me, they don't make the much more expensive 1630 because the less expensive stock-type work just as well.
    And, yes, the thicker gaskets do require slightly longer bolts. So, it comes down to what's more important----a more leak free engine or original headmarks on the bolts?
    • Ronald L.
      • October 18, 2009
      • 3248
      Re: Lessons learned
      RBW head mark bolts I had no problems with mine using the repro silver painted cork.
