C1 Door post whiskers - NCRS Discussion Boards
  • Bob W.
    • August 31, 1981
    • 84
    Is there a tool to set the rivets to install the door post whisker on a 1958
  • Anthony P.
    • June 27, 2010
    • 485
    Re: C1 Door post whiskers
    There is a tool that you can use to crush rivets.
    I used the www.yardstore.com tool http://www.yardstore.com/browse.cfm/4,4753.html
    and also purchased: 16305, 11211, 10110, 16308.
    This let me do all of the rivet setting I needed to do so far including door posts and was very easy to use. I even used this for setting the rebound strap rivets. I still need to do my hardtop.
    Hope this helps,
    Tony
    • Bob W.
      • August 31, 1981
      • 84
      Thanks Bob
      • Joe M.
        • April 30, 1990
        • 1343
        You can also use a small air hammer that can be dialed to to 5 - 9 psi and a heavy metal bar held against the small end of the rivet. I purchased the air hammer from The Northern Tool for < $10, but have not tried it yet. Try googling "Aero Rivet Tool", it will do the same thing and it is < $100.
        • Roger W.
          • January 29, 2008
          • 572
          I have never hear of door post whiskers. What are they?
          • Steven B.
            • June 30, 1982
            • 4016
            The black fuzzy liner in the door post.
            • Roger W.
              • January 29, 2008
              • 572
              Thank you. One thing that I have learned from this board is that no matter how much that you think you know, you will always learn something new here.
