Magnetic Oil Drain Plug Gasket Needed - NCRS Discussion Boards
  • Larry B.
    • October 21, 2010
    • 254
    I put magnetic drains plugs on my '61 & '65. I have tried the neoprene and copper gasket and oil still seeps from the plug. Anyone have a gasket that seals and where to get one? Thanks. Happy 4th
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Magnetic Oil Drain Plug Gasket Needed
    these are what i use. http://www.gen-aircraft-hardware.com/stat-o-seal.asp
      • 43277
      Originally posted by Clem Zahrobsky (45134)
      clem and Larry-----
      These seals are essentially the same as the GM #14090908. These are probably the best seals that GM ever offered for the drain plug application but they are, by no means, leak-proof.
      GM has an improved sealing system which came along later. It uses a special "torque-limiting" drain plug with a special rubber seal which has controlled compression due to the "torque-limiting" plug. These can pretty much eliminate any seepage. Unfortunately, as far as I know they are only available in metric sizes. English sizes have been "orphaned" as far the OEM manufacturers are concerned.
        • 11692
        I use just a tiny bit of ARP thread sealant and the annoying oil drain plug leaks go away.
        • Dick W.
          • 10483
          Loctite PST (pipe sealant w/teflon) seals the plug very effectively. Also lubricates the threads for ease of disassembly the next time.
          Dick Whittington
          • Larry B.
            • October 21, 2010
            • 254
            Thanks Guys!
