Heater cut-out relay on a 70 - NCRS Discussion Boards
  • Steve D.
    • May 16, 2011
    • 106
    Should it have delco-Remy on the top? Or is this one correct? The manual says something about it being black.
  • Edward J.
    • September 15, 2008
    • 6940
    Re: Heater cut-out relay on a 70
    Steve send Joe L. a PM he should be able to tell of the part number is correct for your car. It does look like a blower relay, sometimes the production parts are different than NOS, If the color of the housing is only different just paint it.
    • D S.
      • February 28, 2005
      • 1551
      <LI class=img>Is this what you are asking about?
        • January 31, 1988
        • 43191
        Steve-----
        GM #2072624 is a SERVICE relay for the application you mention. It is not the original relay which was GM #1115887. I do not know the configuration of the original relay but it could very well have had a black-painted cover with Delco-Remy embossment as that was one of the typical configurations for this type of relay during the period.
        By the way, the GM #2072624 relay remains available from GM to this very day.
          • November 30, 1989
          • 11600
          I've seen both plated and black on original cars. Usually I expect to see "Delco-Remy" in raised letters on the top.
          • Jeffrey S.
            • May 31, 1988
            • 1876
            Steve,
            Check the AIM for your year. If the '70 is the same as my '69 it is an 881 which has a black cover with the Delco raised lettering.
            Jeff
