54 waterpump - block compatibility - NCRS Discussion Boards
  • John S.
    • April 30, 2002
    • 37
    I am rebuilding a 54 I have had for several years. The engine block is a 3835911 casting but not an orig corvette (F54YG) engine - it is stamped F54X. The waterpump is definately not 54 corvette. I purchased a correct pump but in trying to fit it I have noticed several problems. 1) the block has a freeze plug where the pump appears to take its water from. Not a real problem - freeze plugs come out. 2) The 54 pump appears to mount with 5 bolts; 4 that replace the old pump mounts (1 outside and 3 inside the 54 pump) and 1 on the lower right. Problem, my block does not have a place for the fifth bolt to thread into. Can I tap the block? Or should I stay with the old pump ?
  • Guy M.
    • November 1, 1993
    • 500
    Re: 54 waterpump - block compatibility
    Pop out the freeze plug and tap the block then use lock tight on the bolt. You will enter the water jacket, I had the same issue. You must use the corvette water pump and base because it lowers the center line of the fan so it doesne hit the hood. Hope this helps
    • John S.
      • April 30, 2002
      • 37
      Guy - thanks for the feedback. Thats what I planned to do but I wanted to hear some feedback before I started drilling a hole in my block. PS: did you have any interferance with the timing gear cover ?
      • Guy M.
        • November 1, 1993
        • 500
        None, make sure you line it up good, im ready to fire up my chassis next month, seems like we have the same problems, let me know if I can help.
        • John S.
          • April 30, 2002
          • 37
          If you want to view my project: log into johnsvetshop.com
