HELP!!! '65 Gauge Cluster re-install - NCRS Discussion Boards
  • Philip A.
    • February 25, 2008
    • 329
    Just received my cluster back from restorer. Have articles and pictures / diagrams for re-install. Problem: There are three capacitors attached to the back and I do not recall where they go? None of the information I have indicates either
    • November 30, 1997
    Re: HELP!!! '65 Gauge Cluster re-install
    Phil -
    All three of those capacitors are shown in your Assembly Manual, section U69, sheet A5. The one with the black plastic 2-cavity female connector (item 5) attaches adjacent to the ignition switch and connects to the brown wire from the dash harness, the one with the pinch connector (item 6) connects to the tan wire leading to the parking brake warning light, and the one with the copper "flag" on it (item 4) has the flag inserted in the outboard cavity of the battery gauge connector.
