1960 fender reinforcement - NCRS Discussion Boards
  • Michael B.
    • March 31, 2008
    • 88
    Hello, I see you can buy medal reinforcement for under the fender on a 60 vette (there can't be to much to it) so my question is has anyone made there own and what gauge medal did you use any suggestions would help Thanks, Michael also were can you buy wide radial white walls at a decent price
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 1960 fender reinforcement
    What "metal reinforcement plate" are you talking about - the one used on '58s ONLY to hang the "tusks"?
    • Michael B.
      • March 31, 2008
      • 88
      This is a piece medal that mounts under front fender and attaches to the (top fender moulding studs )and helps to reinforce top of fender when you are working on car as I understand they may have came on 58's but are recommended for 59 and 60's ?? if you want to strengthen top of fender
      • Dick W.
        • 10483
        Vette Products of Michigan was the reproducer of this strip. It is my understanding that they no longer manufacture this product and it seems that everyone that did stock them has exhausted their supply
        Dick Whittington
        • Erich C.
          • January 31, 2007
          • 137
          I bought a pair a few years ago to use on my '62. I got them from CC. They still list them under pt. #331214. They are heavy gauge metal bent into an "S" shape. They would not be hard to make except they have a slight radius toward the front end. If you look at the photos you will see what I mean. If they are not available I can post the dimensions.
          Erich
          • Michael B.
            • March 31, 2008
            • 88
            Thanks for the reply can you measure the distance from top of the S and the bottom ,and what gauge medal used Thanks again,Michael
            • Gary B.
              • September 30, 1987
              • 305
              I put the Z braces from CC on my `62 and they sure helped when I leaned on the fenders to work on the engine compartment. I fastened them by tacking with a small amount of epoxy so they could be removed if wanted.
              • Michael B.
                • March 31, 2008
                • 88
                I thought they had holes that lined up with top fender moulding studs and used speed nuts that attached TFM,Michael
                • Gary B.
                  • 305
                  They do.... if all the pins are on the outside original trim.
                  • Joe M.
                    • February 1, 2005
                    • 590
                    Metal supports may be in short supply, what about the fiberglass versions?
                    • Erich C.
                      • January 31, 2007
                      • 137
                      Here is a drawing with the dimensions of the reinforcement. The pieces are powdercoated and measure .080" . The closest gauge steel to that dim. is 14 Ga. ( .0747 ). I could not directly upload the drawing from my CAD program so I had to take a picture of it. I hope you can read it okay.
                      Erich
                      • Michael B.
                        • March 31, 2008
                        • 88
                        Erich, thanks for all the info it is just what I needed, Michael
                        • Tom B.
                          • March 1, 1978
                          • 720
                          Corvette Central still lists them for $115. Just checked. I've been thinking about adding them to the'59 if they have them in stock.
                          Tom
