1984 Drain Plug rattles - NCRS Discussion Boards
  • Thomas F.
    • November 11, 2008
    • 205
    If you have some mysterious rattles in your 84 Corvette check out the drain plugs. There are 3 plugs under each seat and these plugs are metal and are made funny. Two of mine, one under each seat were loose and were rattleing. I think this was due to improper jacking of the car which caved in the floor board just enough to loosen these plugs. The other 4 are still good and tight. Any suggestions as to where to find or make replacements would be welcome.
  • Peter M.
    • April 8, 2007
    • 570
    Re: 1984 Drain Plug rattles
    Try Gale Gee. Here is his contact information (click to enlarge photo):
    • Thomas F.
      • November 11, 2008
      • 205
      Thanks Peter, I have temporarily solved this problem by making my own plugs. I cut round pieces of 1/4" stiff rubber, put one on each side of the metal floor and held them in place with a bolt thru the center. This made a very tight fit and no rattles. I will keep this information should I decide to replace these with the original type.
