Po1-po2 - NCRS Discussion Boards
Po1-po2
  • Michael S.
    • August 31, 1985
    • 75
    Po1-po2
    What's the difference between PO1 and PO2 Caps?
    Thanks, Michael
  • Jack C.
    • September 30, 1992
    • 1090
    Re: Po1-po2
    The P01's have the turbine fins terminating pointed at the center cap where the P02 fins are not pointed but flat at the center cap. Do a search from about two years ago and you will find pix and quite a lot of discussion. My 68 has the P01 option noted on the tank sticker but I believe that the actual design change was incorporated during 68 because I have the P02 design which I believe are the original wheel covers.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Terry B.
      • August 31, 1999
      • 607
      Re: Po1-po2
      Michael,
      Here is a picture of a PO-1 that Jack is describing. PO-2's are much easier to find our there than PO-1's.
      Terry Buchanan
      Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
      Corvettes Owned:
      1977 Coupe
      1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
      2003 Electron Blue Coupe
      2019 Torch Red Grand Sport Coupe
      • Dale C.
        • November 1, 1999
        • 844
        Re: Po1-po2
        Another difference is the fin that terminates at the valve stem is shorter on the P01 than the P02.
        • Steven G.
          • November 17, 2008
          • 348
          Re: Po1-po2
          Po1 have a flat removeable center cap, Po2 center caps extend outward, a very noticible difference. Steve
          • Michael S.
            • August 31, 1985
            • 75
            Re: Po1-po2
            Thanks, Michael
            Would someone post picture of PO1 vs PO2 ?
            • Terry B.
              • August 31, 1999
              • 607
              Re: Po1-po2
              Here is a picture comparison of a PO-1 on the left and a PO-2 on the right (Pictures taken by master level judge Mike Treece). I think the outer center caps on PO-1's and PO-2's are the same.
              Terry Buchanan
              Corvettes Owned:
              1977 Coupe
                • 15596
                Re: Po1-po2
                Terry posted new pictures above, but trust me y'all are not plowing new ground. There is an earlier thread on this subject with similar pictures posted by me. If my computer didn't crash a while back I could easily find that thread by trying to post those same pictures again -- the software would point me to the previous posting of the pictures -- but I can't find them in my computer. All this electronic wiz bang stuff is not what it is cracked up to be.
                • Randy C.
                  • March 1, 1985
                  • 154
                  Re: Po1-po2
                  I've seen that style of wheel cover with the flat removable center cap on Monte Carlos of that age, but not Corvettes.
                  Randy C.
                    • 15596
                    Re: Po1-po2
                    Randy C.
                    Randy, Look carefully at the pictures Terry posted. Neither wheel cover has the flat center emblem.
                    • Randy C.
                      • March 1, 1985
                      • 154
                      Re: Po1-po2
                      I missed the mark on making a clear statement. There was a previous comment that the PO1 has a flat center cap and the PO2 has a raised center cap. The pictures definitely show both the PO1 and PO2 with the raised center cap. But I have seen a similar wheel cover with a flat center cap on Monte Carlos (and I believe Impalas) of that era. I don't know what the option code was for those wheel covers - they do look very similar to the PO1/PO2 design except that the center cap is flat.
                      Randy C.
                        • 15596
                        Re: Po1-po2
                        Those of us who visit the Florida Regional in January get to see a Monte Carlo so equipped among the automotive "yard art" on display in Kissimmee's Old Town each year. IIRC it is a 1971, but my knowledge of Monte Carlo's is limited.
                        • Paul O.
                          • August 31, 1990
                          • 1716
                          Re: Po1-po2
                          GM had several versions of Turbine style wheel cover over the years. For Corvette PO1 and the PO2 these were 15" covers. Impala's Monte Carlo's and other Chevy lines had 15" but also a 14" version. Then for each model there were different center caps from flat then a short raised to then the full raised PO1 or 2. Buick Riviera also used a Turbine type cover the center cap was full raised but had a large "R" in it and was gold in color also the cover had a gold hue.
                          The smaller 14" covers the raised ridge that is toward the outer edge the cover is is in the center of the outer ring not at the edge like the 15".
                          I am sure there maybe other versions that I have not not seen but those are the few I know.
                          I also have seen a early 1969 S/N 325 I think PO1's on the left side and PO2's on the right .
                          This subject has been cover many times as Terry has stated check the Archives you will have some reading.
                          Paul 18046
                          • Dale C.
                            • November 1, 1999
                            • 844
                            Re: Po1-po2
                            Randy
                            Not to confuse the situation more but very early in the 68 model there was a flat center cap and not like the chevy car one but more like the PO2 the difference being in the outer ring being flush with the inner ring. There was a picture of this cap in the first advertisments of the delux wheel cover. I don't think this version of the PO1 made it to the production cars.
