1960 Tranny Linkage Quandary - NCRS Discussion Boards
  • James S.
    • June 22, 2008
    • 226
    Well, installing all the components on this thrice gone through tranny. BUT, in my anal analysis compulsive tendencies I have discovered there are many pictures of the reverse rod installed in two different ways-
    - The clip side faces toward the tranny or it faces away toward the firlewall. I have it installed with the clip side facing the tranny. BTW, the linkage is after market from CC.
    What is factory correct?
    Please see pics please.
    Thanks.
    Jim
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: 1960 Tranny Linkage Quandary
    Jim;
    Have you tried both ways and, if so, which way does it work best? The way you have it looks right, but it's been years since I set one up.
    At my age, I try not to do much under car work any more.
    Stu Fox
      • November 30, 1997
      Thanks.
      Jim
      Jim -
      All of the Assembly Manual illustrations for '58-'60 show the rod on the inboard side, and the pretzel clip on the outboard side of the shifter reverse lever (like the photo below of a '59).
      • James S.
        • June 22, 2008
        • 226
        Gents,
        Thanks; as usual this is by far the best forum I have joined; hands down. And no BS kiddy stuff going on in this forum.
        I will go with factory and it does fit a tad better. I was thinking with the rod and clip facing inboard the bend may be too close to the firewall. I originally installed with clip facing the transmission. Thanks again.
        Jim
        • James S.
          • June 22, 2008
          • 226
          Jim;
          Stu Fox
          Stu,
          I hear you. I'm 56 and crawling around without stretching out first kicks the arthritus in gear. This Vette is a buddy's of mine; his wife was willed the car by her Dad; a General in the USAF (fighter jock). The bumper still has the one star and base decal on it. They have been very patient with this ground up resto, but I barely charged them as I have a love for this car knowing it was brought back from the dead and I believe the General is watching my every move!!!
          Jim
