Enclosed are photos of inner (GM # 5955498) and outer (GM # 5955500) headlight buckets (called "headlamp mtg. rings" in Gr. 2.726). The black painted buckets are stamped "A" (inner) and "B" (outer) while the NOS yellow cadmium buckets are stamped "98" (inner) and "00" (outer). The "A" bucket is basically the same as the "98" bucket and the "B" bucket is basically the same as the "00" bucket. I do not remember where I got the black painted buckets as they are common on many GM models in the mid to late 1960's. I believe when I did my frame up restoration of my 1966 Corvette from 1980 to 1995 the original buckets were painted black but at the time I did not pay much attention to the stampings on the buckets. I don't even know where my original buckets are located in my collection of hundreds of boxes. During my restoration I installed a pair of NOS "98" and a pair of NOS "00" buckets which were from Delco boxes (black & gold) with November 1967 date codes on the flaps.
Note that the open slots (for adjusting screws) are slightly different when comparing the black buckets to the NOS buckets.
I have two questions.
Are assembly line 1964-1967 headlight buckets stamped "98" & "00" or "A" & "B"? The stamping is on one of the tabs.
Are assembly line 1964-1967 headlight buckets painted black or are they yellow cadmium plated? I tend to believe that they were painted black.
Dave
Dave
....I didn't realize until AFTER I cleaned them about the date. I went back to the shop last night and I was able to find one date. I only looked at the year and remember it was a "9", I will get back to the shop tonight and get the entire date/code. I'm guessing it may/has to be 1959 instead of 1969 because it is the style of light with "no-lines" in the triangle. It had rained here Monday so it was like tramping thru a swamp, I didn't do a very good job of recording which vehicle everything came off of. I just remember the 67 Impala because I looked at the VIN and was interested because my Vette is a 67. Next time out I will record everything. I guess old dogs can still learn.
