62 fuel pump - NCRS Discussion Boards
62 fuel pump
  • Roger B.
    • June 30, 1991
    • 82
    62 fuel pump
    Can anyone advise status of fuel pump.
    ac stamped on both sides
    number 102240510 on lower casting under left screw hole
    brass bottom 2 outlets one stamped 4701, other stamped 6942.
    thanks
    Roger
  • John F.
    • March 23, 2008
    • 2404
    Re: 62 fuel pump
    Should be like this. AC on top and bottom. MADE IN USA under rim by screw heads. 4656 stamped on ridge near lever facing front of car.
    • David L.
      • July 31, 1980
      • 3310
      Re: 62 fuel pump
      thanks
      Roger
      Roger,
      I assume your "102240510" fuel pump is the "modern" type that can not be rebuilt. It is somewhat universal as it can used to replace the "4701" AC pump (GM # 5621682) used on 59-63 Chevrolets w/283 engine as well as the "6942" AC pump (GM # 6415047) used on 64-66 Chevrolets w/283 engine.
      Dave
      • Anthony P.
        • June 27, 2010
        • 485
        Re: 62 fuel pump
        here is a close up of the stamping
        • John F.
          • March 23, 2008
          • 2404
          Re: 62 fuel pump
          Tony, Looks just like mine.
