'65 Paint codes - NCRS Discussion Boards
'65 Paint codes
  • Loren L.
    • April 30, 1976
    • 4104
    '65 Paint codes
    TSB #1072 dtd 11/19/64 passes on color chips and descriptions from Dupont, Ditzler and RM. On the back of the Dupont sheet under "Corvette Interior Refinish"' you find Balck and White listed under "60 GLOSS"; under "3 GLOSS", you will find White, Black, Dark Blue, Medium Blue, Dark Saddle, Medium Saddle, Silver, Dark Green, Maroon, and Red>
    What's the difference between "3 GLOSS" and "60 GLOSS"?
  • Dick W.
    • 10483
    Re: '65 Paint codes
    Gloss
    Gloss
    Gloss
    Dick Whittington
    • Loren L.
      • April 30, 1976
      • 4104
      Re: '65 Paint codes
      Well Dick, if you're correct there's a helluva lot of cars that have been marked WRONG on interior hardtop trim where the manuals call out "Full Gloss Unrubbed".
      • Dick W.
        • 10483
        Re: '65 Paint codes
        Those numbers came off my spec sheet on PPG DX 685 Flattner
        Dick Whittington
        • Tracy C.
          • July 31, 2003
          • 2739
          Re: '65 Paint codes
          Dick, I've always wondered how the numbers play in the real world. Do they represent a percentage by volumn, weight, or something completely different?
          tc
          • Dick W.
            • 10483
            Re: '65 Paint codes
            tc
            Gloss TC. 0=flat 100=high gloss
            Dick Whittington
            • Tracy C.
              • July 31, 2003
              • 2739
              Re: '65 Paint codes
              Roger that Dickie,
              What I need to know is this...does the gloss "number" signify the ratio of paint to flattener? For example, if I want a "60" gloss level, is my mix ratio 60% paint and 40% flattener ? This wouldn't really make any sense in the lower range of "flatness". A gloss level of "10" would certainly need more paint than 10%.
              tc
              • Dick W.
                • 10483
                Re: '65 Paint codes
                Roger that Dickie,
                tc
                No to the percentages. Rather than take up a page with the data sheet, google PPG DX 685 and you should see a link titles flattening agent form p-162. Click on that link and it has all the mixing formulas
                Dick Whittington
                  Re: '65 Paint codes
                  Roger that Dickie,
                  tc
                  Tracy -
                  The gloss number is a measurement of angular reflectivity of light from the surface; don't have the test criteria - it was a laboratory analysis.
                  • Tracy C.
                    • July 31, 2003
                    • 2739
                    Re: '65 Paint codes
                    Perfect...I'm smart enough to be dangerous now...
                    tc
