powdered rocker ball broke - NCRS Discussion Boards
  • Jerry G.
    • April 1, 1985
    • 1022
    ]I was dynoing a new camshaft in my road race motor small block 64 FI and as i was checking the stamped rocker lash i noticed a ball was broken cleanly in half. This surprised me, Clem explained that the ball was powdered metal not a forging. Anyone ever seen this before? I think i would rather have forged rocker balls.
    What do you experts think about powdered vs forged or cast/ who is a reputable supplier for a race application? jerry
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: powdered rocker ball broke
    Originally posted by Jerry Gollnick (8575)
    I was dynoing a new camshaft in my road race motor and as i was checking the stamped rocker lash i noticed a ball was broken in half. This surprised me, Clem explained that the ball was powdered metal not a forging. Anyone ever seen this before? I think i would rather have forged rocker balls.
    you could check the rockwell hardness of the balls and have some made out of heat treated steel. i would have some fine grooves machined into the ball to help hold the oil like the BBC ones have
    • Jerry G.
      • April 1, 1985
      • 1022
      These are made by Elgin and have the oil groves. There was no burning on any of the ball even the one that broke. They looked perfect
        • 15678
        Are you sure they are powered metal and not heat treated steel? I never knew that such existed.
        You definitely want hardened steel, and I've seen SB rocker balls with BB type grooves.
        • Jerry G.
          • April 1, 1985
          • 1022
          Duke just sent you photo
          • Clem Z.
            • January 1, 2006
            • 9427
            the old original may have been hardened steel but i think the new ones PM.
            • Philip C.
              • December 1, 1984
              • 1117
              I would have roller rockers period. Phil 8063
              • Jerry G.
                • April 1, 1985
                • 1022
                at the monterrey historics race they pull your valve covers to check if your running stamped rockers. i agree roller tips are more reliable but rules are rules
                • Philip C.
                  • December 1, 1984
                  • 1117
                  Too bad, Thats just DUM, everyone would use them, everyone would be even. I guess they dont want everyone to finish. Phil 8063
                  • Domenic T.
                    • January 29, 2010
                    • 2452
                    I checked my balls and they are not powdered
                    DOM
                    • Michael H.
                      • January 29, 2008
                      • 7477
                      The 67-69 SCCA Trans Am Camaro's had to use stamped steel rocker arms and they survived at high RPM for hours.
                      • Jerry G.
                        • April 1, 1985
                        • 1022
                        I'm open for suggestions. this problem, getting stamped rockers to survive, has cost me a motor and several thousand dollars. If anyone knows the combination that works i'm all ears.
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          DOM
                          if you are in a hot high humidity area i would suggest you do that.
                          • Clem Z.
                            • January 1, 2006
                            • 9427
                            looking closely at the picture jerry sent the grainy structure at the break looks to me like PM but i am no metallurgist and i don't play one on the internet. maybe if jerry is using 3/8" studs he could find some old used GM rocker ball that were heat treated steel. i would guess back in the day PM was not even used in car parts.
                            • Scott M.
                              • January 1, 1996
                              • 216
                              Out of curiousity I called Crane to see what their high dollar Nitro-Carb rocker arms use for pivot balls. The rocker arm pivot balls are grooved BUT they are heat treated powder metal as well.
