'65 Gauges problems - NCRS Discussion Boards
'65 Gauges problems
  • Twan B.
    • June 30, 2005
    • 212
    '65 Gauges problems
    It's been a long time since a placed a question.
    I took my '65 for the first time this year for a ride. She started good afther 8 mounth's. she's running well, When i started her for the second time she misstarted i had to start her again with no problem but the needle of my fuel and temp gauges turned half way and still sitting this way and are not came back. I'ts the first time for me with this problem!
    How can i reset those gauges?
    Gr,
    Twan
    #44079
  • Joe R.
    • July 31, 1976
    • 4552
    Re: '65 Gauges problems
    Twan,
    There is no reset to those gauges. I think you have lost more than the two gauges. Probably 12 volts to several things is missing. I don't have access to my wiring diagrams presently. Someone does on the board today. Find the lost 12 volts and everything will work fine.
    JR
      Gr,
      Twan
      #44079
      Twan -
      Check the top fuse in the fuse block - that circuit only feeds four items - temp gauge, fuel gauge, parking brake warning light, and the fuel tank sending unit.
