72 sb base motor water pump 330813 - NCRS Discussion Boards
  • Ed D.
    • December 1, 1990
    • 330
    Car with a May 15th build date with a flat boss on top of pump. Can anyone tell me what months this pump was used on corvettes in 1972.
    Ed
    Ed DiNapoli
    CNJ Chapter Past Chairman/Co Founder
    1972 Targa Blue Coupe, Original Owner,
    Duntov Award, Sam Foltz Award,
    Founders Award, NCRS Gallery VIII
    2011 Corvette Convertible
    NCRS Presidents Award 2014
    • 11697
    Re: 72 sb base motor water pump 330813
    Ed,
    As discussed earlier today, we don't really know how much 330813 (the correct number). Previous inquiries didn't turn up much. My friend's 72 built mid-May has a 3991399, yet yours does not. I suspect usage is quite low.
    I took some excellent photos of that original example this afternoon as I went and spoke with the gentleman after you did. I'll try and post them soon.
    Patrick
    Last edited by Gary C.; June 26, 2011, 05:57 AM. Reason: Poster requested a correction to the thread title part #
      • 43285
      Re: 72 sb base motor water pump 830818
      Ed,
      Patrick
      Patrick and Edward------
      I think the earliest that the 330813 would have been used is April, 1972. That also jives with information in Alan Colvin's book. However, I think that for some period of time it's likely that both the 3991399 and 330813 were used. That period was probably April, 1972 until the end of production 1972.
      During the above period there were probably both part number patterns being used for castings at Saginaw. Most likely, Flint could machine either casting with little, if any, change of tooling. Just when the drilling and tapping of the bypass began, I do not know. Corvette did not require this feature.
        • 11697
        Here are photos of the 330813 that Ed and I saw at Bloomington.
          • 43285
          Patrick------
          The date falls within the period I would expect for the "flat top" 330813 and obviously indicates that this casting would have been available for use on a late 1972 Corvette. The only other application that used this casting was MD/HD trucks.
          • Ed D.
            • December 1, 1990
            • 330
            Patrick and Joe, thanks for the information and the pictures. Patrick it was good seeing you and spending some time with you at Bloomington. I posted this to see if there was any information form others about this fairly unfamilar pump. I will try to get the casting information from the pump while it is on the car, but if I cant I will remove the pully after the National. As I plan on driving the 72 to the National I dont want to take it apart before the drive. Thanks again for all your help.
            If anyone else has data regarding this pump, I would appreciale some feedback.
            Ed
            Ed DiNapoli
              • 11697
              Ed,
              Search is your friend.
              Thread about one with the same casting date:
              https://www.forums.ncrs.org/showthre...30813&uid=3159
              My threads 2 years ago looking for any late cars with this pump:
              https://www.forums.ncrs.org/showthre...30813&uid=5559
              https://www.forums.ncrs.org/showthre...30813&uid=2327
              • Ed D.
                • December 1, 1990
                • 330
                Patrick, Geat deal excellant info. Sometimes we miss the ovious.
                Ed
                Ed DiNapoli
