Gas Gauge - NCRS Discussion Boards
Gas Gauge
+ More Options
Posts
  • Tom F.
    • September 20, 2009
    • 66
    Gas Gauge
    I just had all gauges refurbished and installed my dash. I doubled checked and believe that I reinstalled all of the wiring correctly. Everything has worked fine, but I noticed that the gas gauge jumped up when I turned on the head lights and then it returned back to original position. I checked the ground and everything seems secure. Any suggestions?
  • Terry B.
    • December 6, 2010
    • 73
    Re: Gas Gauge
    It is most likely a grounding problem with the sending unit on the gas tank. I had exactly the same problem which was fixed by adding a ground wire from the sending unit on the tank.
    • Tom F.
      • 66
      Re: Gas Gauge
      Hello Terry:
      Thanks for the suggestion, I'll check it out and add a ground at the sending unit.
      • John F.
        • March 23, 2008
        • 2418
        Re: Gas Gauge
        Just like this!
        • Tom F.
          • 66
          Re: Gas Gauge
          Thanks John !!!
