C1 radio blank plate - NCRS Discussion Boards
  • Ken G.
    • December 11, 2008
    • 98
    Just figured out that for my 57 the radio blank plate is not like the one pictured in Adam's Corvette Restoration guide, specifically not the star-burst but a single horizontal line. Found the photo in the new judging manual and it seems like a small chance of finding an original one. So..
    1) any one have close up photos maybe with a ruler so I can figure out the width and length of the bar and
    2) any one tired to convert a star-burst blanking plate to the horizontal line version. Possibly grinding the star-burst off then making the raised portion?
    3) any idea where to find those special type "Derby" washer nuts? They must have been used on something else made in larger numbers than corvettes!?
    ken
  • Loren L.
    • April 30, 1976
    • 4104
    Re: C1 radio blank plate
    Find the late Dale Pearman's article on this topic in the Restorer.
    • Ken G.
      • December 11, 2008
      • 98
      Thanks, but I cannot seem to find nor open any of the restorer files via NCRS web site. Is it my lack of savy, my computer, or the web site? I am assuming that Restorer articles should be available to members?
      Ken
      • Ken G.
        • December 11, 2008
        • 98
        Just tried my Restorer CD and it won't open either, on two different computers....Grrrr!
        • Doug F.
          • November 1, 1983
          • 322
          the starburst is stamped steel, the straightline is diecast, if you try to grind on a starburst, you will ruin it, i'll dig out my stash and take some pics, the straightline was always harder to find, the starburst must have been the same as 55/56 chevy, the nuts you refer to are called 'Pal' nuts not too hard to find
          • Edward M.
            • November 1, 1985
            • 1916
            This thread might help muddy the waters...
            https://www.forums.ncrs.org/showthre...ighlight=radio
            • Dick W.
              • 10483
              Contact the NCRS office in Cincinati for assistance
              Dick Whittington
              • Mike M.
                • May 31, 1974
                • 8382
                agree with doug. both my radio delete 57's have the diecast block off plates. the nuts aren't difficult to find, its the "mushroom" washers that are difficult to find. my 57 210 post FI radio delete plate is stamped steel. it didn't have the mushroom wawshers, just a flat washer and pal nut.mike
                • Steven B.
                  • June 30, 1982
                  • 3986
                  Ken, someone the past year has advertised reproductions of the single bar blockoff plate. As I recall it may not be 100% but it is probably easier modifying it than a starburst. I believe I saw it in The Restorer or The Driveline.
                  Steve
                  • Edward M.
                    • November 1, 1985
                    • 1916
                    Steve
                    On Ebay...
                    • Gary C.
                      Administrator
                      • October 1, 1982
                      • 17657
                      1956 Bill of Materials (BOM) dated 2-25-56 reads as follows:
                      3706916 Cover Assy Instrument Panel Radio Opening
                      Gary
                      NCRS Texas Chapter
                      https://www.ncrstexas.org/
                      • Gary C.
                        Administrator
                        • October 1, 1982
                        • 17657
                        Ed,
                        Still on a quest to find out what the part number 3707868 is. Possibly it's the "over the counter" part number for the die cast radio block off plate blue print drawing number 3706916.
                        Joe Lucia regularly points out the OTC part number and the AIM part number often differ for the same part.
                        Ken Kayser advises there's no blue print drawing for 3707868 in his file. Ken also says that 3714216 is the blue print drawing number for the straight line stamped radio block off plate.
                        FWIW,
                        Gary
                        NCRS Texas Chapter
                        • Edward M.
                          • November 1, 1985
                          • 1916
                          Originally posted by Gary Chesnut (5895)
                          Ed,
                          FWIW,
                          Gary
                          Could be Gary, I have no further info other than what the P&A says. The mystery continues.
                          Anybody know of a 53 to 55 that did NOT come originally with a radio.
                          • Rod K.
                            • 443
                            Ed,
                            FWIW,
                            Gary
                            Gary,
                            I talked to Dick Bennett of Iowa a couple of years ago at Kissimmee re tooling he has for the die cast straight line plate. IIRC, it is original tooling, not in useable condition, but I'm wondering if it might have a p/n on it or if he might have other documentation. Just a thought.
                            • Gary C.
                              Administrator
                              • October 1, 1982
                              • 17657
                              Rod, die cast plates have the part number on their backside. Gary....
                              NCRS Texas Chapter
