"Double nutting" rocker arms - NCRS Discussion Boards
  • David B.
    • February 1, 2006
    • 12
    A coworker recently had his 396 rebuilt. Appears the rocker arm nuts are backing off. His rebuilder suggests "double nutting" them. I haven't heard of this. Thoughts anyone? Thanks.
  • Loren L.
    • April 30, 1976
    • 4104
    Re: "Double nutting" rocker arms
    Have him start by getting a new engine guy.
    • Ken A.
      • July 31, 1986
      • 929
      Actually, this will work as a cheap alternitive to buying a new set of lock nuts.. But they're a PITA to adjust.
      • Jerry G.
        • April 1, 1985
        • 1022
        There are many suppliers of adjusting nuts with locking set screws. we have used them in racing for many years. But, with new studs and new locking nuts there shouldn't be a problem for street use.
        • Gary B.
          • September 30, 1987
          • 305
          What about the extra weight and balance???
          • Michael H.
            • January 29, 2008
            • 7477
            Whe I rebuilt the 427 in my 66, several of the rocker arm nuts had lost much of their "prevailing torque" quality.
            It was late Saturday night when I was almost finished and I didn't have any new nuts to replace the loose ones.
            I put several on the back side of a vise and hit the top with a hammer to slightly increase the distortion at the top.
            That was 1983 and the same set is still on the engine today, probably 40,000 miles later.
            I wouldn't double nut rocker arm studs. The studs are very hard and a bit brittle. The force generated between the two nuts can easily snap the stud between the nuts. I've seen it happen several times over the years.
            • Clem Z.
              • January 1, 2006
              • 9427
              either the studs or nuts or a combination of both are worn. new ones are the way to go
                • 15634
                I doubt a big block would notice the extra weight (maybe a pound vs 3200 for the car), and the nuts don't move (that is the point of double nutting them) so balance is not an issue. Because they don't move there is no added weight to the valve train, if that was what you meant Gary.
                • Rich W.
                  • March 13, 2011
                  • 146
                  The way to look at it is there are different levels of repair..double nut being one of them..but if the motor was just rebuilt then why wasn't this repaired to the highest standard when it was apart? I have only one machinist I use..only because I know that he will bring it to the highest standard for street use possible..things like this should not go past a machinist who keeps his ducks in a row..either that or your buddy drove him nuts and just wants him gone..or he thought the owner just wanted a quick fix..think there may be more to this Harvey story!
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    i have had good luck using these as rocker arm adjustment lock nuts BUT only with new studs and nuts. http://www.aircraftspruce.com/catalo...151palnuts.php also this adjustment problem could be coming from the cam or parts in the valve train wearing. check the pushrods for wear and even the cam lobes
                    • Stuart F.
                      • August 31, 1996
                      • 4676
                      "Pal Nuts" have been my pals since the mid 50's, starting with the less than steller 55 adjusting nuts. They are cheap insurance and easy to manage.
                      Stu Fox
                        • 43285
                        clem and David-----
                        Yup! I strongly suggest purchasing 16 GM #3921912 rocker studs and 16 GM #3896648 rocker stud nuts. Even at GM LIST price, these will come to less than 100 bucks. If one is going to rebuild an engine, why leave worn parts in there? With these, he'll be back to as-new as far as the rocker studs and nuts are concerned.
                        • David B.
                          • February 1, 2006
                          • 12
                          Thanks to all for the comments/suggestions. I'll pass them on and see what he decides to do.
                            • 43285
                            David------
                            Another option for him would be to use Pioneer brand, rebuilder-type studs and nuts. These are sold in sets and are usually quite inexpensive. They might not be up to OEM quality, but they're a lot better than the worn parts he has now.
                              • 15706
                              clem and David-----
                              You can buy these and virtually any other OE equivalent replacement part in the aftermarket under the Sealed Power brand, and I have no doubt the Sealed Power parts come from the same plant as what GM sells, but are probably a lot less expensive.
