Keep you feet and your LS6 on the ground! - NCRS Discussion Boards
  • Rich G.
    • August 31, 2002
    • 1405
    From the NTSB site. The airplane burned to the ground after an off airport landing due to engine failure. Check out the choice of power plant
    Aircraft: Bowley Murphy, registration: N189SB
    Injuries: 1 Uninjured.
    According to Federal Aviation Administration (FAA) information, the airplane was manufactured by the pilot in 2006. According to the pilot, the airplane was equipped with a fuel-injected Chevrolet Corvette LS6 engine that utilized a "high pressure" fuel system. The pilot stated that all fuel lines forward of the firewall were fire-sleeved. FAA-provided information,which documented a similar event in September 2006, involving the same pilot and the same airplane. The pilot was taxiing at DVT when a fire erupted in the engine compartment; the cause was attributed to a fuel line that became disconnected, and sprayed fuel onto the hot engine.
    • 43271
    Re: Keep you feet and your LS6 on the ground!
    Rich------
    I wouldn't be caught dead flying ANY homebuilt airplane and. especially, any homebuilt using a "converted" automobile engine, of Corvette origin or otherwise.
    • Mike G.
      • July 31, 2002
      • 709
      Rich------
      or you might be caught dead in it.
      • Tom P.
        • April 1, 1980
        • 1826
        Rich------
        Then we won't invite you to fly in ours when it's finished.
          • 43271
          Tom------
          That's not a homebuilt and it certainly doesn't use converted automobile engines.
          • Clem Z.
            • January 1, 2006
            • 9427
            how about this use for the corvette engines ??? http://www.seven-marine.com/motors/technology/
              • 43271
              clem-----
              These engines are basically manufactured by GM and "dressed out" by the various OEM marine engine outfits like Mercury Marine and others. You can find them in the "marine engines" section of the www.gmpowertrain.com web-site.
              • Clem Z.
                • January 1, 2006
                • 9427
                clem-----
                these engines are converted to outboards not inboards like GM sells. this thing has to be quite large for a outboard.
                  • 43271
                  clem------
                  I wonder who would want an outboard engine as heavy and unwieldy as these must be? It would seem like the advantages of an outboard would be effectively negated. One might just as well go with an inboard.
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    clem------
                    those outboard guys like HP as i saw one in Fla. with 4 300HP outboards on the transom.
                      Clem -
                      When 1200hp isn't adequate, some guys go for 2000 .
                      • Dick W.
                        • 10483
                        Clem -
                        Does it tow the fuel tender, or is that a separate boat??
                        Dick Whittington
