'69 rocker molding screws - NCRS Discussion Boards
  • Jeffrey S.
    • May 31, 1988
    • 1890
    I need some assistance with the configuration and size of the 2 screws on each side that go in the two front tabs of the black fiberglass rocker moldings on a '69. These screws go in vertically at the front. The part number is the same as the screws that secure the lower shifter boot on a manual but since I have an automatic I can't check this. The AIM picture looks like it is an indented hex head. What is the configuration and what size socket fits ( I can get the right size if I know the socket size). Thanks!
    Jeff
  • Grant W.
    • December 1, 1987
    • 407
    Re: '69 rocker molding screws
    Hi Jeffery
    Here is the screws on my 68. I had bought an original 69 side fender and it had one set of the original screw and nut. On my original 68 fender I found one set of the same screw and nut in a bag. So I am 100% sure these are the right ones. I only had one slot on each fender so that was a bonus.
    Hope this helps, just a reminder the black side rocker screws. The original black phosphated Philips screws heads fit in the slot perfectly. REpops sit above.
    Thanks, grant
    • Jeffrey S.
      • May 31, 1988
      • 1890
      Grant,
      Thanks for the reply. This is exactly what I was hoping to see. If it's not too much trouble could you tell me what socket size fits this screw? I found some of what appear to be this exact screw in my stash box and I'd like to be sure. The AIM shows a u-nut instead of a nut as you show which clips to the tabs on the body. Thanks for your help.
      Jeff
      • Don L.
        • August 31, 2005
        • 1005
        Originally posted by Jeffrey Salz (13182)
        Grant,
        Jeff
        Mine are 5/16" heads. Also, yes - these are the same screws that secure the lower (manual) shift boot to the floor. Take a look at them next time you are over at my house. Maybe we can deal
        Don Lowe
        NCRS #44382
        Carolinas Chapter
        • Grant W.
          • December 1, 1987
          • 407
          Grant,
          Jeff
          Hi Jeff
          I got 5/16 for the screw bolt and 3/8 for the thin lock washer nut.
          As Don replied- The screw bolt is the same as the manual shift boot???
          Hmm I'm getting some NOS manual shift screw bolts from a friend of mine and the ones he has said it has a thick glob of glue on the threads. When I get them I will post on the board.
          Hope this helps.
          Grant
          • Jeffrey S.
            • May 31, 1988
            • 1890
            Thanks for your responses. I'm off to Bloomington in about 10 minutes so I'll check back on Sunday.
            Jeff
