L36 Before and After - NCRS Discussion Boards
  • Andrew S.
    • July 29, 2009
    • 56
    Finally getting close to my first drive in 18 months in my '66 L36. Thought I'd share some before and after shots of the now-de-bubbafied engine compartment.
    I hope you can tell which is which .
  • Steve D.
    • May 16, 2011
    • 106
    Re: L36 Before and After
    Nice work. Going thru the same process on my 70. Sometimes things can make you just shake your head.
      • 15706
      Very nice. You definitely save one!
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11363
        Well Done!!! Looks Superb!!!
        • Jeff A.
          • November 1, 2005
          • 199
          Excellent job! Went through a similar restoration of my L36 recently. What source did you use for your braided wires? I used Lectirc Limited dated wires for judging, but switched back to my older service replacements for daily driving because of durability concerns (as noted in the archives).
          • Rich W.
            • March 13, 2011
            • 146
            One word..WOW..the more I see these type of cars the more I would like to do it to mine..awesome.
            • Timothy B.
              • April 30, 1983
              • 5202
              Andrew,
              You should be proud, beautiful job!!
              • Andrew S.
                • July 29, 2009
                • 56
                Thanks for everyone's compliments! I will pass them on to the expert who did the real work on the project (and will gladly recommend him to anyone via PM, if desired. Chicago area.). My skill is limited to projects much smaller than this entire engine & engine compartment restoration.
                He used Lectric Limited wires & I intended to use them for driving, too. But now that I note the reliability concerns, I might change my mind.
                • Ronald L.
                  • October 18, 2009
                  • 3248
                  Nice clean up. What PCV valve did you use?
                  • Andrew S.
                    • July 29, 2009
                    • 56
                    Getting back to your question, Ron, I went with the 736 pcv valve based on my late build date of July 7. Am I correct?
                    • Ronald L.
                      • October 18, 2009
                      • 3248
                      There aren't too many people talking about this, but the Bow Tie 390 HP survivor had this at the national and my opinion is the 691 valve remained in use for the 390 HP engine. Later on in service it was replaced by the 736 valve, but we'd need to see 66, 67 and 68 dated service catalogs to make the determination when that change occurred.
                        • 43277
                        Ronald-----
                        The CV-691 valve, aka GM #6421981, was replaced for SERVICE in July, 1969 by the CV-736C, aka GM #6423695. However, the "long numbers" are SERVICE part numbers and, as has been explained previously, PRODUCTION and SERVICE "long numbers" usually differ for these PCV valves.
                        • Tom M.
                          • August 31, 2000
                          • 231
                          Looks great.Are the service dated wires still availible from Chevy?
                          • Ronald L.
                            • October 18, 2009
                            • 3248
                            Chevy No, any of the big box stores have them.
                            • Tom M.
                              • August 31, 2000
                              • 231
                              With Braiding?
