ignition swith removal - NCRS Discussion Boards
  • Roger B.
    • June 30, 1991
    • 82
    How can I remove the ignition swith on my 62?
    I have been told to insert paper clips in the two holes, but nothing happens.
    thanks
    Roger
  • Christopher R.
    • March 31, 1975
    • 1599
    Re: ignition swith removal
    Keep jiggling it. It'll come out.
    A '62 switch is only supposed to have one hole. A switch with two holes is a replacement one. I forget which hole you should use. But put the paper clip in one and turn the key counterclockwise. As I said, jiggle it.
    • Joseph S.
      National Judging Chairman
      • February 28, 1985
      • 818
      thanks
      Roger
      Roger, Make sure the ignition is in accessories position before inserting the paperclip. If there are 2 holes it is the top one for the detent.
      Good luck, Joe
