Windage tray torque - NCRS Discussion Boards
Windage tray torque
  • Dan D.
    • November 5, 2008
    • 1323
    Windage tray torque
    I am about to re-install the windage tray on my 327 after re-doing the oil pump. I had flats & split locks on the windage tray, but after reading some of the post here I decided not to go that route.
    I bought a package of windage tray nuts aftermarket. They are plain nuts with captured external tooth star washers. Don't think you would want or need flat washers with the star washer nuts.
    After reading the archives back to 2003, there is a lot about windage trays, but not fastening torque. It was recommended in one post to use interference thread nuts, but I don't know how one would torque them.
    These are 3/8-16, so I would think 25ft lbs. would be okay. Sound good? Just wondering what some of you guys do.
    Thanks, -Dan-
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Windage tray torque
    Thanks, -Dan-
    i would still use red loctite on the nuts.
    • Ken A.
      • July 31, 1986
      • 929
      I second the loctite & use stock nuts. I've seen them still tight after 30 years on a motor. Loctite is the key.
        • 43248
        Thanks, -Dan-
        Dan-----
        Yes, star lock washers would never be used in conjunction with slpit lock-washers; it's one or the other and neither are a very good thread locking device.
        You could use stover-type lock nuts but why? As clem and Ken have mentioned just use stock nuts with Loctite.
        • Bill B.
          • December 1, 1993
          • 192
          On my 61 FI, if I remember correctly the windage tray is attached to extensions coming off the main caps and are secured with jam nuts. Loctite is not really needed but could be used for a pre-emptive measure.
          Bill
          1961 Black/Silver/Red Int. 283/315 FI
          power windows. Frame off 65% completed.
          1989 White/hard top/Grey Int. daily driver 167,000 miles
          "The problem with Liberalism is that eventually you run out of other people's money" - Margaret Thatcher
          • Dan D.
            • November 5, 2008
            • 1323
            Okay, thanks guys. Joe, I don't know anyone dumb enough to combine split locks and star washers. My comment was about splits and flats, where the star will lock to the flat, but then both are free to rotate about the tray. Flats are not necessary here anyhow.
            I will use 242 threadlocker with the aftermarket nuts. Red 271 Loctite can be very difficult to remove, and I don't think it is necessary in this application.
            No one has commented on the 25ft lbs. torque, which was the original question. So I will go with that.
            -Dan-
            • Clem Z.
              • January 1, 2006
              • 9427
              using any type of lock washer inside a engine is looking for trouble because if they fail you will have pieces loose inside the engine. split lock washers are the worst because they can break into 2 pieces.
                • 43248
                clem-----
                YUP!
                • Dan D.
                  • November 5, 2008
                  • 1323
                  Okay guys, here is the latest plan. I found several of these nuts in my nut & bolt collection. So the plan now is to use these along with Threadlocker 242. How does this sound?
                  On a similar note, the 1/4-20 screws that hold the oil filter bypass plate on. What would you use on those? Just Loctite? Forget what was on it originally. Thanks, -Dan-
