The nightmare continues.
Original 1960 4 speed transmission.
Recall this 1960 4 speed tranny had 70 miles on it from rebuild. First drive on the asphalt and had to double clutch for third gear only. As I put more miles on the car, the tranny began making a whining noise like a worn out truck tranny, so I pulled for inspection. Took it back to the rebuilder and he discovered the following:
Both "new" shift rod levers are worn. New rear and front bearings (made in Japan) now have excessive play.
Removed the pilot bearing and slid over the input shaft. Has about .010 play. Input shaft measures .090. diameter. I compared the measurement to another Muncie that has a new input shaft and the shaft diameters are the same. The pilot bearing came from Corvette Central. I took a magnet and it stuck to the pilot bearing. I was told this was the wrong kind of bushing to install because it has too much carbon, thus less lubrication. What kind of pilot bearing should I use? I will replace the throw out bearing as well. Installed new clutch arm, clutch, pressure plate, clutch arm, etc.
Since I had problems with third gear from the get go, the second rebuilder must have installed components incorrectly. I ensured shift rods, etc., were dead on for adjustments.
I've had two rebuilders now who just don't have the skills or don't care, for measuring all the tolerences for a 52 year old tranny. I'm thinking to ensure a correct rebuild and never having to pull and re-install the tranny ever again, sending it to Larry at D&L who I am told will ensure all tolerences are measured and replace parts.
Any advice is much appreciated (anxiety attacks were abound this evening).
Thanks in advance.
Jim
Thanks in advance.
Jim
