Lower B pillar repair - 1965 - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 934
    What's involved in making this repair ?
    I pulled my coupe body over the weekend and I now want to understand what is involved in making this repair.
    The rocker channel looks fine but the B pillar is rusted badly where the # 3 body mount is.
    Mark
  • Scott M.
    • January 1, 1996
    • 216
    Re: Lower B pillar repair - 1965
    I ended up removing the rocker and B pillar covers and welding new sections to the rocker channels on mine. Both sides were rusted away. Maybe there are easier ways to do it, but thats what I did.
    • Mark P.
      • May 13, 2008
      • 934
      Do you think I can make this repair if I did not want to touch any surfaces now painted body color ?
      I am OK if it is just the wheel wells (blacked-out) or anything under the headliner or carpet.
      That B pillar cover is in the wheel well and comes out by removing some rivets, right ? That should give me full access to the B pillar, right ?
      I was told it is welded in on 3 sides which I assume can be done by just removing the B pillar cover and not having to disturb the body.
      • Scott M.
        • January 1, 1996
        • 216
        That pillar cover is glued to the quarter panel. There isn't much access to it, maybe someone else like Wayne W will chime in.
