Washer hose routing - NCRS Discussion Boards
Washer hose routing
  • Mike R.
    • August 30, 2009
    • 321
    Washer hose routing
    I have three ports on the washer pump on one side and something with two ports on the other. I am not sure if the two port device is a pump or just a selenoid to keep the fluid from flowing out the headlight washers all the time. Where do all the lines go?
    I have the line from the resevoir to the large nipple on the pump but do both wipers connect to one of the outlet ports (with a tee somewhere)? This would allow the other port to feed the two port selenoid. Or does each wiper have its own nipple and there is a tee in the resevoir line (and the two port device is also a pump).
    I have the AIM but the picture is not that clear.
  • Mike F.
    • April 25, 2011
    • 668
    Re: Washer hose routing
    This may help,
    http://forums.corvetteforum.com/c3-t...t-washers.html
    Mike
    • Mike R.
      • August 30, 2009
      • 321
      Thanks Mike this answers my questions I will put it all together this PM.
      Mike
      • Wolf S.
        • July 15, 2009
        • 94
        i just finished renewing bits and pieces and adjusting the headlight door (driver side) and would like to know how the headlight washer hoses are routed in the headlight assembly. is there a speical way? the aim is not so clear.
        thanks
        eat my dust
