Vacuum advance D1383 GM1115360 - NCRS Discussion Boards
  • Jim R.
    • June 30, 2001
    • 643
    Anyone know the specs for this control.
    JR
  • Timothy B.
    • April 30, 1983
    • 5186
    Re: Vacuum advance D1383 GM1115360
    Jim,
    I think the 360 V/A control is 12*@ 12" vacuum.
      • 43222
      Jim------
      GM #1115360 aka Delco #D1383
      inches of vacuum to start the plunger= 7
      12 crankshaft degrees advance @ 12 inches vacuum
      maximum advance= 12 crankshaft degrees
      • Jim R.
        • June 30, 2001
        • 643
        Jim------
        Joe do you know if this was this used on the 70 LT1
        JR
          • 15680
          The data I have indicates that the recent aftermarket version is stamped "B10" and was available under NAPA Echlin number VC1765SP, however, I believe it's been discontinued.
          This VAC was OE on L-72, and in lieu of it I recommend the B20 or B26, which has 16* @ 12".
          I don't know if it was used on '70 LT-1, but the '70 AMA specs that you should be able to download from the GM Heritage Web site should include the VAC specs, which you can then match to a part number.
          • Jim R.
            • June 30, 2001
            • 643
            Thanks Duke, Joe & Tim
            JR
              • 15602
              The vacuum actuator used on the 1970 LT1 (distributor 1111491) uses a vacuum advance unit of 1116201. Jim this information is in the 1970-72 TIM&JG, and has been for a decade or more.
              Your vacuum advance was used on a 1970 L46 (350/350) distributor number 1112021.
              If you are using the Chevrolet parts book these two engines are differentiated by HP (350/350) and SHP (350/370)
              • Jim R.
                • June 30, 2001
                • 643
                Thaks Terry , ( Don't have a 1970-72 TIM&JG)
                JR
                  • 15602
                  Jim, If you are looking for the applications for your 1115360 control, I don't want to mislead you. There may be many other applications than the 1970 Corvette L48 -- I just don't have easy access to that information, and since you asked about 1970 LT1 I went to the most readily available (to me) source..
