C2 speedometer driven gear help - NCRS Discussion Boards
    • 15668
    Re: C2 speedometer driven gear help
    Revs at 60 are (tire revs/mile) x axle ratio: 766 x 3.08 = 2359, which is why I think you might have a 3.08, but that assumes the tach is reasonably accurate, so you should test it against an accurate tech tach.
    Pull the speedometer adapter out of the transmission, verify the color and tooth count of the driven gear, then look inside the transmission and record the color of the drive gear and if possible, count teeth on the drive gear.
    There's really no point in speculating until your current configuration is verified.
      • 43219
      Duke and Don------
      Usually, the wrong DRIVE gear will not mesh properly if an incompatible DRIVEN gear is used. However, both of the common drive gears used for 1966 have the same tooth count so even if a wrong combination did happen to work, it should not cause an indicated speed problem in most cases.
      The DRIVE gear originally used for a 1966 Corvette with 3.36:1 rear ratio was a steel gear of GM #3708144 and of 1.85" OD. I expect that's still what's in there now. However, it would still be a good idea to check the DRIVEN gear, but primarily for condition. It's very easy to remove but be careful that the gear doesn't fall out of the fitting and fall into the extension housing.
      I'm beginning to think that the problem here is in the speedometer instrument, itself.
      • Donald H.
        • November 2, 2009
        • 2580
        #18
        Ok, I'll pull the driven gear out and check it. Man I need to buy a lift. Jacking it up and setting under jack stands is a PITA
        Don Harris
        Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
          • 43219
          #19
          Donald-----
          ...just don't get tempted to use the jack alone and leave out the jackstands for a "quick" job like this. That can be a "ticket to eternal life".
          • Donald H.
            • November 2, 2009
            • 2580
            #20
            Donald-----
            Yes, I've gotten more cautious in my old age. I not only put in jack stands but also leave a floor jack under both sides
            Don Harris
            • Donald H.
              • November 2, 2009
              • 2580
              #21
              Duke, were does the tire rev per mile come from? How is it calculated?
              Don
              Don Harris
              • Donald H.
                • November 2, 2009
                • 2580
                #22
                Don
                Never mind, I figured it out. Mile divided by Tire circumference equals rev/mile. I measured the tire with a tape ( not the most accurate) and I got 27" so the rev/mile with this would be about 747 versus 766. I try to get a better measurement of the tire diameter
                Don Harris
                  • 15668
                  #23
                  Don
                  Same places I've listed in the last 10 years - tire dealers - like The Tire Rack Web site - and manufacturers' Web sites.
                  Revs/mile cannot be calculated using "rigid body" inflated OD because tires distort under load. They are not like steel railroad wheels.
                  Manufacturers actually measure them and they must be within a tight industry standard range for each size.
                  Do an archive search is you need a more detailed explanation.
                    • 15668
                    #24
                    No, you are wrong.
                    See my previous post.
