Dangling wire help - NCRS Discussion Boards
Dangling wire help
+ More Options
Posts
  • Rob M.
    • April 30, 2003
    • 657
    Dangling wire help
    Alright, I have discovered a loose wire and I am hoping someone can tell what is and where it should be attached.
    I was looking under the dash and noticed that there is a capacitor attached to the cluster. It looks to be between the oil pressure gauge and the temp gauge. The wire is from the capacitor and is a baby blue or gray color with a black plastic end cap of some sort. Where should that end cap be attached?
    Thanks in advance
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
  • William C.
    • July 15, 2009
    • 239
    Re: Dangling wire help
    Thanks in advance
    Rob..There should be a female plug it plugs into with a brown lead from the wiring harness. According to the wiring diagram for a 67 it's a capacitor for the radio...Bill
    • Rob M.
      • April 30, 2003
      • 657
      Bill,
      Thanks for the reply. I'll look for the brown wire.
      Rob
      '08 6 speed coupe
      • Stuart F.
        • August 31, 1996
        • 4676
        As I recall, the plastic cap encloses a female faston which would/could mate to a male faston attached to one of the gauge cluster enclosure mounts. That's from an old memory as I hate to get under there any more.
        Stu Fox
          Bill,
          Rob -
          It's shown in your '66 Assembly Manual in section U69, sheet A5, item #5 at the lower left of the illustration. The capacitor wire has a 2-cavity female connector so it can accept another male connector if you have power windows.
