Seized engine - NCRS Discussion Boards
Seized engine
  • Robert I.
    • July 31, 2004
    • 164
    Seized engine
    Trying to get a stuck engine to rotate.
    How much torque can I put on the crankshaft bolt?
    I can get it to turn, but not the crank.
    If Marvel Mystery Oil doesn't work, would it do any good to remove the heads and spray some PB Blaster directly around the pistons?
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: Seized engine
    Bob,
    You can remove the plugs and put your favorite penetrating oil thru the spark plug holesthen usa a rubber tipped air nozzle and push it in the plug hole one at a time till you find one or so with compression.
    The air pressure should move the piston down.
    If that dosen't work then turn it at the flywheel using the teeth with a flywheel turn tool or a LARGE screwdriver.
    DOM
    • Timothy B.
      • April 30, 1983
      • 5202
      Re: Seized engine
      Robert,
      I agree with Domenic, turn the engine at the flywheel and don't strip the crankshaft screw. Lots of penetrating oil first..
      • Dick W.
        • 10483
        Re: Seized engine
        Patience! Give the MMO plenty of time to work, maybe a couple of weeks. Go to the flywheel and try to turn it both ways. Keep doing this every few days until it breaks free. I have a rather large engine (586 cu in) that took over two months to free up
        Dick Whittington
        • Doug F.
          • November 1, 1983
          • 322
          Re: Seized engine
          even if you get it to turn it will still need "work" on at least two cylinders, so the heads have to come off anyway, so other than the satisfaction of getting the engine to turn over, what have you accomplished for all the time you have spent? we have encountered plenty of engines where getting the piston out of a block with no heads or crank, without splitting the wall was a major trick
          • William G.
            • April 1, 1978
            • 154
            Re: Seized engine
            ROBERT
            Purchased a 67 427/390 that had been sitting for 5 plus years amd
            was frozen up. I removed the sparkplugs and filled each cyl with
            transmission fluid and let set for 4 hours. When i came back it rolled
            over and started. Maker sure it is outside because it will fill the
            street with smoke.
            Good Luck
            Bill
            • Dick W.
              • 10483
              Re: Seized engine
              Do not try to push the car to break the pistons loose. You can end up bending a rod. If the car is a manual transmission, you can put it in 4th gear and try rocking the car back and forth. Too much effort and you can break the ring lands on the pistons
              Dick Whittington
