LS-1 stamped rocker in early small block - NCRS Discussion Boards
  • Jerry G.
    • April 1, 1985
    • 1022
    I'm in discussion with a cam supplier and in the course of discussion about stamped rocker life they suggested I switch from a standard nitrated stamped rocker to an over the GM counter LS-1 rocker. They claim its built to higher quality standards than any aftermarket rocker. This is racing applicatioin so rocker life is important. First; will an LS-1 go on an early 292 head setup and second has anyone succesfully done this?
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: LS-1 stamped rocker in early small block
    LS engine rocker arms have a 1.7 rocker ratio and to use them i think you would have to move the stud location as they did using BBC rockers on SBC. why can't you use the roller rocker that were used on LT-4 engines as they were std equiptment ???
    • Clem Z.
      • January 1, 2006
      • 9427
      when using stamped steel rocker make sure you have plenty of oil getting to the rockers. do you see any bluing of the broken rockers as this means you need more oil to them to keep them cool because if they are getting hot they will loose strength. i would use the lightest valves you can find and use beehive type springs because they need less tension to control valve float.
      • Jim L.
        • September 30, 1979
        • 1816
        Jerry's racing application requires stamped rockers, per vintage rules. No roller tip rockers, no roller trunnion rockers. Just 1955-tech stamped rockers. Oh, and 7500 RPM would be nice, too.
        Jim
          • 43263
          Jim
          Jim------
          I can't imagine that LS-1 rocker arms would work on a Gen I or Gen II small block. But, even if they will, they are investment cast, not stamped steel, and have some sort of "roller" trunnion.
          • Jim L.
            • 1816
            Jim------
            Thanks, Joe. I was aware that LS-7 rockers have roller trunnions, but didn't know about other LS engines. I sent Jerry a suggestion regarding a rules-compliant rocker arm that will likely survive the RPM he needs to turn.
            Jim
            • Jerry G.
              • April 1, 1985
              • 1022
              Part of my problem was self inflicted,as usual, I had restictors left in the oiling system from when it was dry sump and the lifters were a design that only oiled part time. This has been fixed and there now is plenty of oil. The other part of the problem was that I had too much lift(.610). This is the reason i'm talking to a cam supplier
                • 15706
                Did they by chance mean LT1 (circa 1991) rockers. Maybe they were better than previous stamped designs (?).
                The LT4 used (I think Crane) roller tip rockers.
                  • 43263
                  Duke-----
                  Yes, the 1992-96 LT1 rockers are adaptable to any Gen I small block. In fact, they were also used in PRODUCTION on 1987-91 L98 and have been SERVICE for all 1955-86 small blocks for many years. These are stamped steel rockers with GUIDED type design (tough to use on any mechanical lifter engine due to lash measuring difficulty).
                  The 1996 LT4 rockers were cast aluminum with roller tip and roller trunnion. They were manufactured by Crane.
                  • Jerry G.
                    • April 1, 1985
                    • 1022
                    Duke-----
                    So for my mechanical lifter application these LT-1 would not be a good fit?? Is that correct?
                      • 15706
                      Correct. You can't use a "guided" rocker arm with mechanical lifters.
                      Given the reduced lift and required spring force, I don't think you'll have any more rocker problems.
                      The Crower catalog is on line and has spring requirements for all cams, but you can use any spring, including a beehive type, that has the same or similar specs.
                        • 43263
                        Jerry------
                        In my opinion, the best rocker arms of the stock, standard stamped steel type are the Crane Nitro-Carb rockers. However, I don't know if they're part of the product line of the "New Crane" company.
