1960 gas tank - NCRS Discussion Boards
1960 gas tank
  • Donald H.
    • November 2, 2009
    • 2580
    1960 gas tank
    May be a dumb question, but I need to purchase a new gas tank. Looking at Quanta. The correct tank for my 60 did not have baffling but the later 61-62 did.
    Is there any reason not to go with the one that if baffled? Is this something that is judged or can be judged to determine if there is baffling or not?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Joe M.
    • April 30, 1990
    • 1338
    Re: 1960 gas tank
    How would judges know that it was a baffled tank without inserting something inside the filler neck or examining the bottom of the tank or top of tank to see spot welds that hold baffles in place? There is no scientific evidence behind my response, just gut talking.
    • Donald H.
      • November 2, 2009
      • 2580
      Re: 1960 gas tank
      I don't know and thus my question. As someone doing my first restoration and trying to conform to NCRS it sometimes can get frustrating.
      I had another thread about U-joints. I need to replace the U-joints as I finish the chassis restoration. The TIM&JG only says that the U-joints need to be the greaseless type. Fine, I found some at NAPA and ZIP. When I put my question on the forum to see who had used or recommended either, the response I got was that neither would pass NCRS judging. The originals have a bowtie cast into the body of the U-joint and a circular configuration.
      Now for sure, the TIM&JG makes no mention of this, so there must be a lot of things that are judged that are not mentioned in the TIM&JG. I guess if we were all lucky enough to have an all original car then judging would only be problematic for condition. Not sure what someone like me does who has a car that has many small parts that haven't been original for years and the TIM&JG may or may not be a complete guide!!!!!!!!
      Sounds like I am bitching, which is probably true, but this is a very expensive hobby and I just want to do the restoration as correct as I can.
      Don
      Don Harris
      • Donald H.
        • November 2, 2009
        • 2580
        Re: 1960 gas tank
        Anyone used the baffled tank in a 60?
        Don Harris
        • Jerry C.
          • November 1, 1995
          • 741
          Re: 1960 gas tank
          I have used the 61/62 tank in the past and no one would ever know unless you did a PV. You can save some money by getting the tank from Auto City Classic @ 800 828 2212.
          • William B.
            • April 30, 1975
            • 939
            Re: 1960 gas tank
            How do they check tank during a PV?? How can anyone tell if baffles are present after car is assembled?
            • Jerry C.
              • November 1, 1995
              • 741
              Re: 1960 gas tank
              Lak of hearing the gas sloshing around when cornering.
              • Donald H.
                • November 2, 2009
                • 2580
                Re: 1960 gas tank
                Jerry,
                Since you've used the baffled tank, what is the big difference as for as driving the car? I'm not planning to be driving my 60 hard afer it is finished, so is there a big deal of baffled versus non-baffled as far as normal curising?
                Don Harris
                • William L.
                  • January 18, 2011
                  • 8
                  Re: 1960 gas tank
                  You will be glad you went with a baffled tank if you park the car on an unlevel area and the gas is leak=ing out on the ground through the vented cap. Ask me how I know.
                  • Jerry C.
                    • November 1, 1995
                    • 741
                    Re: 1960 gas tank
                    Just less noise of the gas moving around when the tank is not full.
